Any advice on adding a middle seatbelt?
Better to buy a drivers or passenger side?
Anyone have a Holly green belt for sale?
67 F100 Adding Middle Seat Belt?
- GTWilliams
'77 F250 XLT
Camper Special
460ci, 4x2
Bright Dark Blue (S) & Silver Metallic (J)
Deluxe Style paint scheme
Camper Special
460ci, 4x2
re: 67 F100 Adding Middle Seat Belt?
A factory driver's/passenger's side seat belt won't work for a middle belt, since you don't want one that will retract. Ford didn't start using a retractor until '67, so if you can find an earlier truck to grab some good belts from, you can use either side to add to the middle position of yours....the bolt holes are already there in the cab floor.
Otherwise, any newer vehicle with belts would work. The middle position won't be equipped with retractors, so it's just a matter of going to your local Pick 'n' Pull and grabbing one out of almost any vehicle....if they'll sell you a used belt. Some won't, due to liability concerns.
- 71-F-250SC-72-F-250C
The 71 did not have a middle belts when we got it, and my dad got lucky and found a green one in the junkyard. Green belts are hard to find for some reason. Most are black. Good luck.
Stephen
Stephen
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
- prime mover
dam I need a green one too what if you found one and took it apart disabling the retractor?
72 F-350 crew cab, 59 mercury parklane, 64-1/2 mustang
The belt is wrapped around the retractor pin, so in order to use it you'd have to leave at least the retractor frame that holds that pin, but you'd have to cut the sides of it off in order to clear the seat frame when mounted. I don't see why you couldn't remove the retractor spring so it would always stay extended.
I'd just be careful doing this. Function is more important here than appearance. If you can find a middle belt from another vehicle that doesn't have the retractor but is a different color, you can very easily dye it to match your interior. Personally I think that would be a better choice.
The rear seats out of an econoline van, bronco, crew cab, maybe some of the cars, may fit.
I haven't installed it, but I got a couple of belts out of the rear seat of an econline. I would have liked green like you guys, but these are light blue.
Former owner of 70 LB SportCustom and a 71 SB SportCustom. Looking for a replacement bump!
They will fit and match exactly in some of the cars from a simular year. That is what my dad got his out of and it looks like his other belts and looks like the original one that came in my 72.
Stephen
Stephen
72 f-250 Custom
03 mach1 mustang
72 f-250 Custom
03 mach1 mustang
