Morning guys... I can't figure out how to close the gap in my 71 steering wheel. won't even trip my turn signal.
Thanks
Ron
Gap in the steering wheel
- Ron_Hall
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
Re: Gap in the steering wheel
The steering wheel is fixed to the steering shaft, which is fixed to the steering box thus it is not going to move. You have to move the steering tube UP toward the steering wheel to close the gap. Loosen the clamp on the tube that's in the engine compartment and under the dash. Once loosened, move the tube up to the desired position then tighten.
- Ron_Hall
Mach428...Mach428 wrote:The steering wheel is fixed to the steering shaft, which is fixed to the steering box thus it is not going to move. You have to move the steering tube UP toward the steering wheel to close the gap. Loosen the clamp on the tube that's in the engine compartment and under the dash. Once loosened, move the tube up to the desired position then tighten.
Thanks, I'll give it a try.
Ron
One owner...
One owner...
- Ron_Hall
Hi Mach428... I must be missing somethingMach428 wrote:The steering wheel is fixed to the steering shaft, which is fixed to the steering box thus it is not going to move. You have to move the steering tube UP toward the steering wheel to close the gap. Loosen the clamp on the tube that's in the engine compartment and under the dash. Once loosened, move the tube up to the desired position then tighten.
Thanks
Ron
One owner...
One owner...
Then it's stuck. If you look at the clamp under the steering column inside the cab, you'll notice that the mounting holes are elongated for the purpose of adjusting the column tube up and down. The steering shaft and steering wheel are fixed
You may have to put some penetrating oil at the point where the tube meets the firewall flange and the mounting clamp inside the cab. These are the only two points that holds the tube in place.
Your column bearing retainer cones are locking it down, that's their job. You'll have to remove your steering wheel and wiggle the top one loose. Also, when you do that, the lower bearing retainer and clamp will have to be reinstalled snugly.
- Ron_Hall
Thanks Randy!! took me 5 minutes to close the gapsargentrs wrote:Your column bearing retainer cones are locking it down, that's their job. You'll have to remove your steering wheel and wiggle the top one loose. Also, when you do that, the lower bearing retainer and clamp will have to be reinstalled snugly.
And Mach428, Thanks for your help also.
Ron
One owner...
One owner...
