Learning to weld
hdpusher
Re: Learning to weld
Post by hdpusher »
If you are new to welding a tip on safety.
DO NOT use brake cleaner to degrease or clean parts before welding. The heat will vaporize the fluid creating phosgene gas. This is hazardous and can be fatal.
Read the warning labels on the cleaners before you use them. Most will list if they are unsafe for welding and most are.
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold :cry: )
78 CJ5
03 Dodge Cummins
Mancar1
Post by Mancar1 »
Why thank you for the info hdpusher.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
67mann
Post by 67mann »
hdpusher wrote:If you are new to welding a tip on safety.
Great info and certain metals such as galvinzed.......nasty. Big key in welding.....Ventilation and lots of it :thup:
Whateverman
Post by Whateverman »
i was given this advice when i was forced too start my career as a welder (stick at the time,but it applies to MIG as well) the old welder i worked with was kinda crusty and i had to censor a fair bit of the actual language used but its still gets the basic jist of things across pretty well : "Its kinda like ^%$#& icing a $#@!^ cake - No not that @#$%^& frosting $&@$- you know that fancy (crap) they *&^%$ squeeze around it?....okay...if you're &^%$# doing it right it's gonna sound like yer frying *&&%$ bacon.. okay see ya later i gotta go"
ToughOldFord
Post by ToughOldFord »
Whateverman wrote:i was given this advice when i was forced too start my career as a welder (stick at the time,but it applies to MIG as well) the old welder i worked with was kinda crusty and i had to censor a fair bit of the actual language used but its still gets the basic jist of things across pretty well : "Its kinda like ^%$#& icing a $#@!^ cake - No not that @#$%^& frosting $&@$- you know that fancy (crap) they *&^%$ squeeze around it?....okay...if you're &^%$# doing it right it's gonna sound like yer frying *&&%$ bacon.. okay see ya later i gotta go"
:lol: :lol:
That guy sounds like he knew his &#@!! :lol:
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
Dismantalus
Post by Dismantalus »
Just to reinforce hdpusher's point on the Brake Cleaner. Many of the "Non-Chlorinated" bake cleaners switched to a neat little chemical called Methelene Chloride. Used in cabinet stripping. Really bad for the 'ol Central Nervous System all by itself, even without the heat and uv from the arc. Try to use only something like Acetone for cleaning the areas to be welded. I can't begin to tell you how many shops I have visited (I'm a Certified Welding Inspector) to do Welder testing, and the first thing that comes out is the Brake Clean....
jamesdfo
Post by jamesdfo »
Yup, Brake Kleen is Bad News, see link below......
http://www.brewracingframes.com/safety- ... e-gas.html
James
