hooking up an original AC unit in a non AC truck????
dablack00
Post by dablack00 »
Ok guys, I'm looking at some original AC units to put in my 71 short bed. Has this been done before? I'm sure I can figure out the AC lines, but what about the electrical? Any advice?
BigRedTruck
re: hooking up an original AC unit in a non AC truck????
Post by BigRedTruck »
mine was a dealer add on orginal. they had to drill two holes in the fire wall and the hoses come very close to the exhaust manifold. i'll try to get a picture up tonight
69 F-100 2wd 360 cid C6
dablack00
Post by dablack00 »
Big Red,
That would be great. There are some pictures on this site of the units and where the holes are but some pics of it installed would help too. What will really need help with is the wiring. Maybe when I get it, you can help me run down the wires.
thanks
Austin
BigRedTruck
I got some up in my album now but i have more now that i'll be adding once i figure out which old pics to remove to make room
DuckRyder
Post by DuckRyder »
Actual "FACTORY" A/C has the compressor standing up, and the hoses enter the fire wall through a large oval bushing about the center of the firewall.
Most of the period add on units have two holes drilled just right of the brake booster.
Can't help with the wiring, but It will be pretty simple I bet.
oldschoolrods
Post by oldschoolrods »
I have a 1969 truck shop manual at home (at school right now) when I go home tommorow I will see if it has a wiring diagram for a 69 A/C (i dont imagine they changed too much) If it does I'll bring it back to school with me on monday and try to post it then.
dablack00
Post by dablack00 »
Big Red,
thanks for the pics.
Old School,
A wiring diagram would rock! Thanks again guys.
Austin
68F250
Post by 68F250 »
Here's the wiring diagram for the ’70 - ’71 factory air conditioning, below are the wire numbers and colors for a ’72 (can’t find them for this diagram), I think they’re the same, Ford’s usually pretty good about keeping the same numbers and colors.
21 - Yellow
37 - Black w/ Yellow Stripe
38A, 38B – Black
57 – Black
181 – Brown
257 – Yellow
268 - Red
269 - Blue
270 - Black w/ Yellow Stripe
297, 297A - Black w/ Green Stripe
348, 348A - Green
359 - Black
515 - Orange
68F250
Post by 68F250 »
oldschoolrods,
not trying to step in front of you but the wiring diagrams are in a separate manual so I just scanned it.
barry
oldschoolrods
hey thats fine, I just looked in my manual and all I had was an a/c schematic anyway so no hard feelings here :P
dablack00
Post by dablack00 »
Thanks guys. I will be doing this in the next couple of months. I will report on the findings.
Austin
